Cisco Aironet 1100
I am working Cisco Aironet 1100, i am trying upgrade flash.
I copied the the file c100--- from new device and planned to copy to other, i removed the flash and suddenly the connectivity went off and restarted it showing red light.
Hot to upgrade/install the OS now, how to connect?
it has only ethernet port no console port.
Please help me know
1 REPLY
Re: Cisco Aironet 1100
Sounds like the best course of action for now would be to try a factory reset on the unit, see the following Cisco doc for instructions on how to do this:
http://www.cisco.com/en/US/docs/wireless/access_point/1100/installation/guide/110h_c5.html#wp1057541
If the device can load an image, it will now default to trying to find an IP address via DHCP, so make sure it can do that and then try and connect using the Web or Telnet interface.
Hope this helps,
Jonathan
348
