Community Member
Cisco and huawei --VSS AND CSS ?
Deare Cisco expert:
I got one questions about VSS. I have no idea about the requirements of VSS. Now. I have two 3 layer core switches,but the vender is different: one is CISCO WS-C4506-E , and the other is huawei s9300 .I know cisco need vss, huawei need css. Is it mean I cannot use virtualization between them? Another question, can VSS be enable between 4500 and 6500?
Hello, as far as i'm aware you cannot use the Cisco and huawei to form a virtual cluster. For Cisco you need exact like for like to form a VSS.
No you cannot use VSS between a CAT4500 and CAT6500, but you can with 4500 and 4500 or 6500 with 6500. Remember only some versions of code and some SUP's support this.
Depending on your requirements if both support VRRP as a first hop redundant gateway this could be your solution.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Community Member
Re: Cisco and huawei --VSS AND CSS ?
For VSS every parameter should match like hardware,module & IOS .
1165
