Switching
Get 20% off switches when you combine Cisco solutions
Labels
Good day;Need help with how I can configure NAT overload with an existing vrf on a CAT9K_IOSXE V16.12.  This is what I am struggling with, I currently have a vrf called AWSDX-S3.  Now what I am trying to do is I have added a L2 SW and ran trunk ports...
gurowar by Level 1
  • 145 Views
  • 4 replies
Resolved! mac flapping
Apr 16 04:14:35.390: %SW_MATM-4-MACFLAP_NOTIF: Host 001b.0907.fe0e in vlan 11 is flapping between port Gi1/1/1 and port Gi1/1/2Apr 16 04:14:35.390: %SW_MATM-4-MACFLAP_NOTIF: Host 001b.0907.fe0e in vlan 11 is flapping between port Gi1/1/1 and port Gi1...
Is it necessary to change the MTU for SVL links in a scenario in which interfaces are configured with MTU larger than default 1500 bytes?Traffic could flow between chassis through SVL links in a Stackwise Virtual cluster. Could not find any reference...
ckuwajima by Level 1
  • 44 Views
  • 0 replies
Resolved! PBR VS CONNECTED
hello. I understand that Connected routing has an AD value of 0. The IP bands on the 1st and 2nd floors are different. 1st floor: 1.1.1.0/242nd floor: 2.2.2.0/24 There are two firewalls on top of the backbone. The band will be 3.3.3.0/24. If you conf...
김선명 by Level 1
  • 233 Views
  • 8 replies
I get the following error message: https://pastebin.com/WEwAvbsCThe network is shown in the image. I literally just press start all devices, connect to console and get that. I tried googling the error but nothing shows up.
The VLANIF of the core switch acts as the gateway for client. The Client is unable to obtain the gateway IP, but by manually adding ARP, it can communicate with the gateway. The core switch has the correct MAC and ARP information for the client, a...
Translator by Community Manager
  • 138 Views
  • 4 replies
Hi Team, Two switches are connected to each and that link is a trunk port between those two switches, The challenge is on one switch when I perform cdp/lldp neigbor detail I can see the other switch which is connected to it but funny thing when I pin...
hi friendsi config below commands to configure AAA authenticate with Microsoft Active Directory 2008(CIsco Device Integrate with AD microsoft for telnet and ssh and both can login to console by AD and local username) but while i unplugged Cisco Devic...
zavira123 by Level 1
  • 54358 Views
  • 14 replies
  • 1 Helpful votes
