Cisco cat 6506-E VSS boot problem
Hi all,
I got some problem today, I tried to upgrade IOS from SXI2a to SXI9 in cat 6506 VSS. But the problem is that switch always boot with old IOS. I put the new IOS in sup-bootdisk and slave sup-bootdisk, bootvar is ok with new IOS:
show redundancy
Redundant System Information :
       Available system uptime = 3 hours, 32 minutes
Switchovers system experienced = 0
              Standby failures = 0
        Last switchover reason = none
                 Hardware Mode = Duplex
    Configured Redundancy Mode = sso
     Operating Redundancy Mode = sso
              Maintenance Mode = Disabled
                Communications = Up
Current Processor Information :
               Active Location = slot 1/5
        Current Software state = ACTIVE
       Uptime in current state = 3 hours, 31 minutes
                 Image Version = Cisco IOS Software, s72033_rp Software (s72033_rp-IPBASE-M), Version 12.2(33)SXI2a, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 02-Sep-09 01:00 by prod_rel_team
                          BOOT = sup-bootdisK:s72033-ipbase-mz.122-33.SXI9.bin,1;
        Configuration register = 0x2102
Peer Processor Information :
              Standby Location = slot 2/5
        Current Software state = STANDBY HOT
       Uptime in current state = 3 hours, 27 minutes
Show bootvar  is ok but switch always boot with old IOS SXI2a, any idea???, some bug in IOS sxi2a???, I will try to delete de old IOS from sup bootdisk and try with the new one only.
Regards.
Everyone's tags (3)
VIP Super Bronze
Re: Cisco cat 6506-E VSS boot problem
What does the running config show?
Can you post the output pf Sh run ! Inc bin?
Hall of Fame Super Gold
Maybe the SXI9 image is corrupt.
Check the bootstring.
Check the location of the SXI9.
Hi thanks for reply,
boot-start-marker
boot system flash sup-bootdisk:s72033-ipbase-mz.122-33.SXI9.bin
boot-end-marker
I verified checksum MD5  of the IOS in 6500 after copy and it's the same of the MD5 Cisco web page.
Regards.
Thanks for the output.
May I ask if you can furnish the output to the following commands:
1.  dir sup-bootdisk:
2.  dir slavesup-bootdisk:
997
