Cisco Catalyst 2911 Basic Configuration
Hello people,
Im installing a new router in the company (a 2911) and Im having some trouble making it work.
Basically, Im having trouble with the internet conections.
Im conecting one provider to G0/0, another one to G0/1, and then the network to G0/2.
Im not trying to make load balance work (not yet, first I want at least one conection working), so I have unplugged the cable in G0/1. G0/0 is up and running, and I can make pings from the router to internet with no problem.
The problem is that the network can not reach internet at all.
I leave you the running-config, to see if you can give me a much apreciated hand.
router1#show running-conf
Building configuration...
Current configuration : 5806 bytes
! Last configuration change at 20:46:29 UTC Sun Jan 26 2014 by alan
! NVRAM config last updated at 17:07:05 UTC Fri Jan 24 2014 by alan
version 15.1
service password-encryption
hostname router1
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp pool LAN_DHCP_POOL
network 192.168.0.0 255.255.0.0
default-router 192.168.2.2
domain-name g_test
dns-server 8.8.8.8 208.67.222.222
lease 0 8
no ip domain lookup
ip host router1 192.168.2.2
ip name-server 8.8.8.8
ip name-server 208.67.222.222
ip name-server 8.8.4.4
ip name-server 208.67.220.220
crypto pki trustpoint TP-self-signed-2101532551
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2101532551
revocation-check none
rsakeypair TP-self-signed-2101532551
crypto pki certificate chain TP-self-signed-2101532551
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32313031 35333235 3531301E 170D3131 31323239 32313137
  31335A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 31303135
  33323535 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100DEA3 06574FDF B2B2113F 84A1EF39 04131994 9969F4D9 A3FCC466 D0328CCF
  B219F1AE A3DCC204 CD993BB2 F59C9A7F C251024E F1A575A5 5C382162 D9277CEB
  0356C896 A7A1BB48 8EA4CFF6 DA77B72C 9904A73B 6731A6E0 3004E5EA B44C1F7F
  5667496C 1E8E603D BE9B1AA1 1065E449 F6110C17 1A5FE3B9 3593BF87 96E14DEC
  87FF0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14E5F8C8 C30593C3 CEAB1874 F94F070B 9674F152 AD301D06
  03551D0E 04160414 E5F8C8C3 0593C3CE AB1874F9 4F070B96 74F152AD 300D0609
  2A864886 F70D0101 05050003 81810092 51314A50 EA812CDA AC97A8D1 2CA06BCC
  6FD5B4A6 DA888322 E2166AB4 0CF340BB E0407C95 584A1BDF 5DC3A6EE 2862E9CF
  7BF0C831 54F06ABF 011664D3 75269FF3 02D434BD 0FD15F32 EB34730C 47FE29D9
  7C2BBF9D 5BDB1D4F EEBFBED5 9B07450E 83DA57B2 1F296D0A 52D39A8F 6A679244
  05C0924C F3FA9A05 BDB28409 53198E
        quit
license udi pid CISCO2911/K9 sn FTX1553AJQU
username alan privilege 15 secret 5 $1$b6Jk$8iz3K3cTUgSZ.VePkKl5a/
redundancy
class-map match-any PROHIBIDAS
match protocol http host "www.facebook.com"
match protocol http host "www.youtube.com"
match protocol http host "www.pornotube.com"
match protocol http host "www.xvideos.com"
match protocol http host "www.mega.co.nz"
match protocol http host "www.radios-on-line.com.ar"
match protocol http host "www.enlaradio.com.ar"
match protocol http host "www.cienradios.com.ar"
match protocol http host "www.radios-argentina.com.ar"
match protocol http host "www.fmyam.com.ar"
match protocol http host "www.piratebay.org"
class-map match-any P2P
match protocol winmx
match protocol gnutella
match protocol bittorrent
match protocol kazaa2
policy-map DROP_PROHIBIDAS
class PROHIBIDAS
  drop
policy-map DROP_PROHIBIDOS
class P2P
  drop
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description Fibertel
ip address dhcp
ip access-group acl101 in
ip access-group acl101 out
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
no cdp enable
service-policy output DROP_PROHIBIDAS
service-policy output DROP_PROHIBIDOS
interface GigabitEthernet0/1
description arnet
ip address dhcp
ip nat outside
duplex auto
speed auto
no cdp enable
interface GigabitEthernet0/2
ip address 192.168.2.2 255.255.0.0
ip nat inside
ip tcp adjust-mss 1452
duplex auto
speed auto
no cdp enable
router rip
version 2
network 192.168.0.0
ip forward-protocol nd
ip http server
ip http port 8180
ip http access-class 20
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 200.122.102.1
access-list 101 permit ip any any
control-plane
banner exec ^C^C
banner login ^C^C
banner motd ^C^C
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
Thanks in advance!
Everyone's tags (5)
2 ACCEPTED SOLUTIONS
Hi Alan
You have done the relevant IP Nat statements on your inside and outside interfaces but you have not told the router which LAN subnets it needs to NAT.
Try this:
#access-list 100 permit ip 192.168.0.0 0.0.255.255 any
#ip nat inside source list 100 interface Gi0/0 overload
Glad it worked.
You were halfway there in that you had told the router which interfaces were Inside (LAN) and Outside (WAN) but the router also needs to be told which subnets it needs to NAT.
When the packets hit the router from the LAN, they have a source address of 192.168.*.* and the router needs to translate this address to the Public IP address so it can be routed onto the internet.
Just an FYI, you are using a fairly wide /16 subnet mask for your LAN (255.255.0.0) but this may be intentional, thought I would mention it.
Hello Alan,
What are your plans on using nat?
I see you use a private ip address on GE0/2, While GE0/0 and 0/1 are using DHCP.
I usume the isp's provide these interfaces with public ip's?
In that case you will have to configure NAT\PAT
Hello Wender Putters,
You are correct, Im connecting G0/2 to my network and G0/0 and G0/1 to different ISP's with different public IP's.
Haven't I already configured NAT/PAT?
ip address dhcp
ip nat outside
duplex auto
speed auto
no cdp enable
description arnet
ip address dhcp
ip nat outside
duplex auto
speed auto
no cdp enable
ip nat inside
duplex auto
speed auto
no cdp enable
Hi Alan
Try this:
It worked!!! MANY MANY THANKS!!!!
Glad it worked.
Yes, I know its preeeety wide, but for testing porpuses I wanted that, I will tune it up later.
Thanks!
I will start playing with the load balance... to see if I can make it work
1028
