Community Member
Cisco Catalyst 2948G-L3 doesn't boot
I have a Cisco Catalyst 2948G-L3 in my lab environment. The router doesn't boot anymore.
As you can see, the firmware image is corrupted somehow. Is there ANY way to recover the image file.
ROMMON: Cold Reset frame @0x00000000
ROMMON: Reading reset reason register
ROMMON: Valid NVRAM config
System Bootstrap, Version 12.0(7)W5(15) RELEASE SOFTWARE
Copyright (c) 1998 by cisco Systems, Inc.
ROMMON: Initializing exceptions
ROMMON: Initializing TLB
ROMMON: Initializing cache
ROMMON: Sizing and zeroing main memory ... 64 MBytes
ROMMON: Sizing non-volatile memory ... 128 KBytes
cat2948g platform with 65536 Kbytes of main memory
boot: cannot determine first file name on device "bootflash:"
rommon 1 > dev
Devices in device table:
id name
bootflash: boot flash
eprom: eprom
rommon 2 > dir bootflash:
File size Checksum File name
3310848 bytes (0x328500) 0xf08d cat2948g-in-mz.120-18.W5.22b.bin (bad checksum: 0xf07d)
BR mpohjola
Community Member
Re: Cisco Catalyst 2948G-L3 doesn't boot
So... is the only way to recover the router replacing the NVRAM chip or can the file be recovered by another way?
The set of commands is limited when the firmware is not loaded.
BR mpohjola
Purple
Community Member
(second try...)
The current rommon version is older than required version. --- "Perform file transfer from the ROM monitor with either Cisco IOS Release 12.0(7)W5(15a) or later."
And as you can see, the rommon version of the device is:
The router doesn't recognize xmodem -command.
Should I just recycle this piece of hardware? Can I order somewhere/somehow nvram -chip containing a valid version of uncorrupted version of boot image?
BR mpohjola
Hall of Fame Super Gold
RMA the switch.
652
