cisco catalyst 2960 IOS ver12.2(53)se2
Pls help
have
cisco catalyst 2960 IOS ver12.2(53)se2 when power on the power LED does not come up and on this is what shown on hpertermianal
what need to be done for this switch pls?
Boot Sector Filesystem (bs) installed, fsid: 2
Base ethernet MAC Address: b4:d9:8d:27:4c:00
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
flashfs[0]: 536 files, 19 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32514048
flashfs[0]: Bytes used: 3671040
flashfs[0]: Bytes available: 28843008
flashfs[0]: flashfs fsck took 10 seconds.
...done Initializing Flash.
done.
Loading ""...: no such device
Error loading ""
Interrupt within 5 seconds to abort boot process.
Boot process failed...
The system is unable to boot automatically.  The BOOT
environment variable needs to be set to a bootable
image.
switch:
switch:
Thx
joseph
  • LAN Switching and Routing
1 ACCEPTED SOLUTION
Hello Joseph,
Hmmm... This seems as if the IOS image was deleted... Can you please enter the following command and post the results?
dir flash:/c2960-lanbasek9-mz.122-53.SE2
Thank you!
Best regards,
Peter
get in the ROM and re-initialize the flash according the machine you have.
Maybe you will lose the config but it should fix the issue.
Alessio
How pls,
help step by step pls
thx
Joseph,
Please capture and attach the output of the two following commands entered in the bootloader mode:
set
dir flash:
Thank you!
Best regards,
Peter
switch:
switch: set
CLEI_CODE_NUMBER=COMMK00ARF
MAC_ADDR=B4:D9:8D:27:4C:00
MODEL_NUM=WS-C2960-24TT-L
MODEL_REVISION_NUM=J0
MOTHERBOARD_ASSEMBLY_NUM=73-12600-04
MOTHERBOARD_REVISION_NUM=B0
MOTHERBOARD_SERIAL_NUM=FOC14480GCB
POWER_SUPPLY_PART_NUM=341-0097-03
POWER_SUPPLY_SERIAL_NUM=DCA14458PDJ
SDM_TEMPLATE_ID=0
SWITCH_PRIORITY=1
SYSTEM_SERIAL_NUM=FOC1415X4WV
TAN_NUM=800-32797-01
TAN_REVISION_NUMBER=D0
VERSION_ID=V02
switch: dir flash
unknown cmd:dir
switch:
Hello Joseph,
It is possible that you have used a special key, such as an arrow key, TAB or similar, when you entered the dir flash: command. That is the reason why the command was not accepted - these keys are not supported in the bootloader mode and actually cause the following command to be rejected as unknown.
Press Enter a few times in an empty command line to make sure that no remaining (invisible) characters have been left unprocessed in the command line buffer. Then enter the following command once again:
dir flash:
Remember to write the colon after the "flash" keyword. Do not use TAB, arrows or any other special keys. If you happen to make a typo, use only the Backspace key to erase the line and correct the typo.
Waiting for your reply.
Best regards,
Peter
switch:dir flash:
Unknown cmd:dir
switch: dir flash:
Directory of flash:/
    2  -rwx  1048                     multiple-fs
    3  drwx  192                      c2960-lanbasek9-mz.122-53.SE2
28843008 bytes available (3671040 bytes used)
switch:
Hello Joseph,
Alright. Try entering the following commands very carefully without any typos (as you can see above, using the special keys inevitably leads to trouble):
set BOOT flash:/c2960-lanbasek9-mz.122-53.SE2/c2960-lanbasek9-mz.122-53.SE2.bin
boot
Ideally, try to copy these both commands onto clipboard and then paste them into Hyperterminal by right-clicking anywhere in the Hyperterminal window and choosing the "Paste to Host" function (avoid using Ctrl-V - that won't work).
Post the results back here please.
Best regards,
Peter
switch: set BOOT flash:/c2960-lanbasek9-mz.122-53.SE2/c2960-lanbasek9-mz.122-53.
SE2.bin
switch: boot
Loading "flash:/c2960-lanbasek9-mz.122-53.SE2/c2960-lanbasek9-mz.122-53.SE2.bin"
...flash:/c2960-lanbasek9-mz.122-53.SE2/c2960-lanbasek9-mz.122-53.SE2.bin: short
read: bad mzip file
Error loading "flash:/c2960-lanbasek9-mz.122-53.SE2/c2960-lanbasek9-mz.122-53.SE
2.bin"
switch:
Hello Joseph,
Thank you!
Best regards,
Peter
4334
