Community Member
cisco catalyst 2960CG-8TC-L
I have a switch  cisco catalyst 2960CG-8TC-L (mini switch), and I can't connect it
with telnet because there is no login local on it, and I can't write on this switch this
command. Does someone know the command of this switch for enable login local?
Everyone's tags (1)
1 REPLY
VIP Purple
Login local should not effect
Login local should not effect telnet its for reverting to the username/password config when you come in by vty ports, You can configure telnet access from the gui you should be able to access it then once the password is set , not all commands/features would be aviolable as in the 24/48 port models
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/hardware/quick/guide/ol14970.html
You can check what your software support in feature navigator
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
76
