Community Member
Cisco Catalyst 2960G WARNING: The switch is not usable
I am having an issue with a working Cisco Catalyst 2960G.
I have amber lights with System and RPS.
I have connected it through console. At least the OS gets started. However, the following message appears:
!!! WARNING: The switch is not usable !!!
Unable to create l2trace server process, socket_open() failed
Press RETURN to get started!
*Mar  1 00:00:18.446: hl2mcm_core_process: hl2mcm_install_hl2mcm_ctrl_entries() failed.
*Mar  1 00:00:18.446: %SYS-3-HARIKARI: Process HL2MCM top-level routine exited
*Mar  1 00:00:19.184: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlanCannot Get the number of ports in MAC notification
*Mar  1 00:00:19.453: %SW_VLAN-4-IFS_FAILURE: VLAN manager encountered file operation error: call = ifs_read_until (header) / file =  / code = 21 (Is a directory) / bytes transfered = -1
-Traceback= A3806C A38780 17E07C 17A1C4 E073A0 DFE068
*Mar  1 00:00:20.518: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 12.2(44)SE6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 09-Mar-09 18:10 by gereddy
*Mar  1 00:00:20.535: Unable to open UDP socket on CMP_PORT
Switch>
Can you please help.
1 ACCEPTED SOLUTION
Purple
Re: Cisco Catalyst 2960G WARNING: The switch is not usable
  Agreed ,   the switch is no good . Get it RMA'd....
Bronze
This is a hardware problem on the switch. You should get it replaced.
Purple
2210
