Cisco catalyst 3560 configure
I have cisco 3560 series switch i want to configure using rj45 rollover cable, my pc has no com port, how can i configure using LAN and is it possible to configure using cisco packet tracer
1 ACCEPTED SOLUTION
Hello faizkt777,Using Serial
Hello faizkt777,
Using Serial to USB adapter you can resolve your problem. If you install the right driver, it would generate COM Port so you can configure your switch with it. Another option is to use  cisco usb console port, if it is provide with your switch. you can download the cisco driver here,
https://software.cisco.com/download/release.html?mdfid=282979369&softwareid=282855122&release=3.1
Try and let us know if this suggestion can solve your problem.
Rate and marked as correct if it is the case.
1 REPLY
Hello faizkt777,
67
