Webcast-Catalyst9k
Cisco Catalyst 3560 Port security
I have configured Port security in 3560 switch it is working fine only the issue I am facing is
once I change IP address of that Host the switch Port go shutdown
since I have configured port security I believe I am changing the IP Address not the host or LAN card
hence the MAC  address is the same the switch port should not tern down.
port config
Interface FastEthernet0/23
switchport access vlan 201
switchport mode access
switchport port-security
switchport port-security mac-address sticky
switchport port-security mac-address sticky 001d.7d26.1296 vlan access
Please help me on this
Everyone's tags (3)
1 REPLY
Re: Cisco Catalyst 3560 Port security
When the interface goes down can you see anything in the logging?
Can you test this again and run the following on the switch:
#sh logg
#sh interface | i proto
#sh port-security interface
Also from the switch can you run:
#sh version
#sh runn
Finally for this host how do you change the IP address and trigger the issue?
/Gary
1512
