Community Member
CISCO Catalyst 4510R
Dear All;
i have CISCO Catalyst 4510R configured in my company. i just added WS-x4306-GB module. Fiber terminates in this modules. please help me how to monitor and check that module.
i will wait for your kind reply
Re: CISCO Catalyst 4510R
You can use " Show module " to check if module is working fine on the chassis.
What do you mean by monitor, Do you want to montior the traffic on the links. Please explain.
You can use SPAN for the same.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/12_2_31a/config/span.htm
HTH,
-amit singh
Community Member
Dear Amit;
Thank you very much for your kind reply;
i use "show module" it works fine. my another question is this;
how cuold we diagnose this module. using "sh module" command it shows that status that it exists. but is there any technique to check the connectivity issue, monitoring as well?
Hi Friend,
In general you can issue "sh logs" to find various messages and as per your requirement you can enable different logging levels.
Also see this link to check port status and connectivity
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/12_2_37s/config/connect.htm
For enviromental monitoring
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/12_2_37s/config/pwr_envr.htm
Ankur
*Pls rate all helpfull post
331
