Cisco Catalyst Express 500 Series Switch config guide
i need to configure cisco Catalyst Express 500 Series Switch.
How do i console into it,can someone please provide me with config guide on this device,basic.
Thanks,cheers.
Hall of Fame Super Blue
Re: Cisco Catalyst Express 500 Series Switch config guide
Have a look at this link which gives some basic configuration examples.
http://www.cisco.com/en/US/products/ps6545/prod_configuration_examples_list.html
Be aware that there is no CLI as such for these devices altho i belive there is a basic CLI than can be accessed through the GUI.
Jon
Thanks Jon,but how do i console into it,thats my main concern,please reply thanks.
Hmm, i'm afraid that is the point. Unfortunately you don't console in because their is no CLI available without the GUI interface.
Best to have a read of the links posted by myself and Pravin as to how configure these switches.
Jon
Hmmm Gods own creation 500 series. Yes No Cli
Attached is the doc.
Also use this software for further management and configuration.
Cisco Configuration Assistant
http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=281144436
You will need a cisco login to get it.
Hope this helps.
Thanks,you solved my problem,am grateful,cheers.
Thats great.
Its a stable switch.
The only part is that it has standard configuration through web which makes it more confusing
2289
