Cisco CE500 Critical error
I have several switches that report in their logs "Port FaX is blocked by Sapnning Tree Protocol".
When I run diagnostics, it says link OK!
Can anyone explain what's going please?
Bronze
Re: Cisco CE500 Critical error
Are you running IOS 12.2(25)FY on those switches? Any other errors being displayed?
Yes we are running 12.2(25)FY on the switches.
Here are the errors I have:
2-Critical Port Fa9: This port is blocked by Spanning Tree Protocol (STP). Aug 08, 2008 08:25:36
2-Critical Port Fa12: This port is blocked by Spanning Tree Protocol (STP). Aug 08, 2008 08:25:36
2-Critical Port Gi1: This port is blocked by Spanning Tree Protocol (STP). Aug 08, 2008 08:25:36
2-Critical Port Gi2: This port is blocked by Spanning Tree Protocol (STP). Aug 08, 2008 07:01:56
Thanks for your time,
Said
Bronze
Said,
What is connected to those ports? Computers on the Fa ports and switches/routers on the Gig ports? If you are using smartport role "other" then you most change them for "Desktop" (Fa ones) and depending how the other ends are configure, on the Gig ports you should use "Switch" or "Router"
Let me know...
Bronze
Said,
One thing I forgot to mention, if you are getting those errors at the moment the ports are going up after being down then are informational messages only and normal STP messages. You may want to clear the log and monitor.
I cleared the logs many times and they keep coming back.
Bronze
What about the smartport settings and the type of devices attached to those ports
The gig ports are switches. I will get back to yo about the fa ones.
thanks
on the Fa ports only workstations.
Bronze
Ok so what smartports are you using on fa and gig interfaces?
on the 24 ports: Fa are for workstations and Gig 1 & 2 are for switches.
On the 12 ports: 1 through 10 are for workstations and 11&12 are for Switches.
Bronze
Ok so under Configure>Smartports you have:
24ports: Fa 1-24 selected as Desktop?
Gig 1-2 selected as Switch?
12ports: Fa 1-10 selected as Desktop?
Fa 1-11 selected as Switch?
Or are you using "other", "IP Phone + Desktop" or any other value. What I'm trying to confirm/discard is if you have anything misconfigured for the type of devices you are using...
Fa 11-12 selected as Switch.
For my Linksys APs I choose "other"
Bronze
99% of the time, those errors are related to misconfigurations. Assuming smartports were properly selected to work with other devices, computers and switches and errors are not generated when the link goes down and then back up, then these errors are either cause by a problem with that 12.2(25)FY software or by incompatibility issues with other devices or by reasons that must be investigated by TAC.
Thanks for your time Gary.
312
