Webcast-Catalyst9k
Cisco configure prof. Express запускается без wizard
CCPE запускается, но без wizard, переустанавливал ccpe, не помогает, в чем проблема ? Что делать? Роутер cisco 861
Everyone's tags (1)
VIP Purple
can you provide the config of
can you provide the config of the router so can see what way its setup ?
я вас не понял,я устанавливаю
я вас не понял,
я устанавливаю ccpe с файла скачанного с cisco.com через setup.exe
я сниму видео чтоб вы поняли
I did not understand you, I set ccpe a file downloaded from cisco.com through setup.exe I wanted you to understand video
VIP Purple
I don't know what video your
I don't know what video your talking about ?
I asked for the running configuration to see if you have configured Cisco CP correctly using the HTTPs protocol with authentication in cli so it works and you can access the router that way from a local device ,it requires more than just placing the file in flash to get it working
https://youtu.be/O2hMGec1j5k
my problem. when I first open ccpe no wizard appears
VIP Purple
I cant see from that video
I cant see from that video what configuration has been put on the router to support cpe
VIP Purple
everything you have
everything you have configured and set in your config and the video output looks correct , try Google chrome or firefox , if that doesn't work I would try load another version of cpp to your flash as there could be an issue with the one loaded
No browsers do not correct
No browsers do not correct the problem, I put CCPE 2,4 it also did not help
my configuration after a
my configuration after a reset of the router
моя конфигурация после сброса
моя конфигурация после сброса  роутера
88
