cisco core switch_4503e management IP address
mfouad.jahmi
dear guys,
am trying to upgrade the software of the core siwtch 4503e, i could not get the managemenet ip address up and running.
what i did is the following :
interfave vlan 1
no shu
then my laptop ip address is 192.168.1.100 255.255.255.0
result pinging from CLI is request time out.
is there any els command where i need to input ?
appreciate the quick support plss
thanks,
MJ
13 Replies 13
terrencepayet
Hi Mohamad,
  • Have you configured any vlan on the switch? If yes make sure that you're in the right vlan.
  • Can you post your config.
HTH.
Terence
flokki123
Level 3
Level 3
hi mohamad,
do you try to ping from the CLI of the switch to the pc? if yes, try it vice versa as maybe the firewall of the pc is blocking the ping. you can also disable the firewall for the test on the pc.
can you post the output of the show interface command for the interface where the pc is connected to.
regards,
florian
mfouad.jahmi
thanks guus,
dear terrence,
yes i am configuring Vlans . and herein the config;
show run
Building configuration...
Current configuration : 1522 bytes
version 12.2
no service pad
service compress-config
hostname dwtc-core4503-cr
boot-start-marker
boot system flash bootflash:cat4500e-ipbase-mz.122-53.SG2.bin
boot-end-marker
enable secret 5 $1$tt3q$U0tUmQD6HeDwIybnKEt4n1
no aaa new-model
ip subnet-zero
ip vrf mgmtVrf
--More--         !
vtp mode transparent
power redundancy-mode redundant
spanning-tree mode rapid-pvst
spanning-tree vlan 1-1042 priority 0
vlan internal allocation policy ascending
vlan 30
name CCTV
vlan 40
name Car_Park
vlan 50
--More--          name Management
vlan 60
name Storage_1
vlan 70
name Storage_2
vlan 100
name DWTC_HQ
interface FastEthernet1
ip vrf forwarding mgmtVrf
no ip address
speed auto
duplex auto
interface TenGigabitEthernet1/1
no switchport
no ip address
! interface TenGigabitEthernet1/2
  switchport mode trunk
  interface GigabitEthernet1/3
interface GigabitEthernet1/4
interface GigabitEthernet1/5
interface GigabitEthernet1/6
interface Vlan1
interface Vlan30
ip address 10.100.30.1 255.255.255.0
interface Vlan40
ip address 192.168.100.1 255.255.255.0
--More--         !
interface Vlan50
ip address 10.100.50.1 255.255.255.0
ip http server
line con 0
password cisco
login
stopbits 1
line vty 0
password cisco
login
line vty 1 4
login
end
dwtc-core4503-cr#show vla
dwtc-core4503-cr#show vlan
VLAN Name                             Status    Ports
1    default                          active    Te1/2, Gi1/3, Gi1/4, Gi1/5
                                                Gi1/6
30   CCTV                             active
40   Car_Park                         active
50   Management                       active
60   Storage_1                        active
70   Storage_2                        active
100  DWTC_HQ                          active
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
30   enet  100030     1500  -      -      -        -    -        0      0
40   enet  100040     1500  -      -      -        -    -        0      0
50   enet  100050     1500  -      -      -        -    -        0      0
60   enet  100060     1500  -      -      -        -    -        0      0
--More--
dear fiokii,
yes i did ping from both sides but request time out.
i was surfing the doucment of configuration of 4500 series and i fund out the following, pls let me if i am correct to do the following commands,
The Ethernet management port, also referred to as the Fa1 or fastethernet1 port, is a Layer 3 host port
to which you can connect a PC
If you want to use Fa1 port for TFTP operation, configure the Fa1 port as the source interface for TFTP
as follows:
Switch# ip tftp source-interface fastEthernet1
* i guess  i should clear the config of interface vlan 1 and instead of that configuring the interface fastethernet1 with the same IP_Address 192.168.1.1/24 and then input the command which is :
the above command might give me the access to the tftp server which installed in my PC and then i get connectivity.
let correct if am wrong , am gonna do the above right now and will see the result.
the following task to do are the follwing :
1- clear the config of interface vlan 1
2-configuring the interface fa1
3- input the command  Switch# ip tftp source-interface fastEthernet1
4-configuring the PC in the same subnet 192.168.1.100/24
regards,
MJ
Hi Mohamad,
This management port doesn't rely on VLAN. You'll need to configure a static ip address on the fa0 (lets say 192.168.1.2/24). Once you've configured, you should be able to ping the interface from your laptop/pc (192.168.1.100/24).
The input command for the tftp is correct.
HTH.
Terence
Terrance,
Thanks for your input.
I did the tftp coomand as the following ;
#ip tftp source-interface fas 1
#interface fast 1
#ip add 192.168.1.1 255.255.255.0
# no shut
Then , PC ip address is;
192.168.1.100/24
Gateway is 192.168.1.1
I ping from CLI but no chance , request time out.
I ping from PC to switch. YES i got reply.
The. WhT could be the problem?
Hi Mohamad,
Arent you using 192.168.1.1/24 on interface vlan 1??
In case you've cleared vlan 1, then you might have a firewall issue on your pc as suggested by florian.
Terence
Terrance,
I cleared the vlan 1 config with coomand no ip address.
NOte that without ip routing coomand the PC cant reqch the switch
Also i found something while booting,
In the rommon mode, u know that u configure the ip address and subnet mask and tftp server ip addresses, actually i did configure them thru romon mode with different ip range addresss, i guess now it is conflicting with configuration i made thru normal mode.
What do u think? Am confused :s
Terrance,
Shall i erase everything ans start again..
Then what is the orooer command to do so ?
Ijust wanna clear all the miss and start with fresh switch.
Hi Mohamad,
Nop i dont think so. The issue is that you're unable to ping your pc from the switch. You'll need to sort out this issue before troubleshooting tftp.
Have you check your firewall on your pc?
and also post sh int fa1
Terence
terrance,
show    show inte
dwtc-core4503-cr#show interfaces fa
dwtc-core4503-cr#show interfaces fastEthernet 1
FastEthernet1 is up, line protocol is up
  Hardware is Fast Ethernet for out of band management, address is 0025.84b1.8c57 (bia 0025.84b1.8c57)
  Internet address is 192.168.1.1/24
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, 100BaseTX/FX
  Last input 00:00:00, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     535 packets input, 49686 bytes
     Received 0 broadcasts (0 IP multicasts)
     0 watchdog
--More--              144 packets output, 12198 bytes, 0 underruns
--More--              0 output errors, 0 collisions, 2 interface resets
     0 lost carrier, 0 no carrier
dwtc-core4503-cr#ping 192.168.1.100
Sending 5, 100-byte ICMP Echos to 192.168.1.100, timeout is 2 seconds:
Success rate is 0 percent (0/5)
dwtc-core4503-cr#
and about the firewall settings, i did the following:
windows firewall > turn windows firewall on or of >  i make it off
and am connecting point to point to switch.
let me know what shall i do in order to upgrade the software ?
am not able to get connectivity from the swich to the PC , it sounds really wired issue but surly there is something missing,
am on site actually and whaterver in your mind, pls let me know
  You should be able to do the following .  Step A , turn off any pc firewall before you begin anything .  You are using vlan 1 as your management , by your config the following ports are in vlan 1 ,
                                                Gi1/6
Plug your pc  into one of those gigabit ports 1/3 -6 .  Give your pc a address in the vlan 1 address range 192.168.1.X  , your pc nic gateway will be 192.168.1.1 . On your tftp software on your pc make sure you are pointed to the correct directory where your image is stored .  If using windows verify your address setup on your pc . From a DOS command prompt issue ipconfig /all .  This will give you your nic addressing setup, if correct try pinging the default gateway 192.168.1.1 . If it pings start your download to bootflash: .
Dear glen,
The 4503 have 2 modules, supervisor6L-E where I have two uplinks X2 SFP module, the other one is SFP12-E .
All the ports are SFP modules for connectivity between edge and core switches. The only Ethernet port is the management 10/100/1000 MGT where I pluged my PC to it directly.
What other things to do ?
hi mohamad,
if you cant ping the pc from the CLI of the switch, but you can ping the switch from the pc then i guess there is still some security software on your pc preventing the ping.
if the settings on the switch would be wrong then the ping wouldnt work at all.
check your anti virus software. can you connect your pc to another pc and try to ping again?
Florian
