Webcast-Catalyst9k
Cisco Express 500
10 express 500 and 2 2960 are uplinked to a 3750 .
PC's getting dhcp address from all 2960's and 3750 itself .
but not with express 500 .
Hall of Fame Super Gold
Re: Cisco Express 500
Can you provide more information about your network? How about the configs for the Express 500?
Gold
This is just a wild shot in the dark.
have you configured the 500 switches uplink port as uplinks ? ie the port you connect between the 500 and the 3750.
good luck
Have you checked the status and configuration of the interfaces. This is most likely a trunking issue.
You should ensure you CE500 ports connected to the 3750 are set to trunk ports.
You will also want to ensure that you have ip helper-address assigned to these vlans so that these ports can get a dhcp address.
HTH, Please rate if so
Justin
190
