10-19-2014 10:04 AM - edited 03-07-2019 09:10 PM
I need a switch which will accommodate 32 x LC single mode fiber SFP modules. I've used smaller metro switches in the past with 12 SFP ports but am unsure about the Cisco range.
Could someone recommend a switch that could do this? I've seen the MDS 9148 but am unsure if I can utilise the ports this way.
Any pointers would be helpful.
10-19-2014 10:18 AM
You can use a Cisco 5548. It comes with 32 1/10Gig ports. If you add the additional 16 port module you can go up to 48 ports. All ports are LC and you can use Multi-mode or single mode SFPs or SFP+. The switch is 1RU.
datasheet:
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-5000-series-switches/data_sheet_c78-618603.html
10-20-2014 03:46 AM
Is there any recommendation against Nexus 3K? For example 3172PQ (or even older ones, like 3064X) could match the requirements.
There's also the 4500-X...
10-20-2014 09:42 AM
Hello.
You can also check out the new Cisco 6800 switches:
http://www.cisco.com/c/en/us/products/switches/catalyst-6800-series-switches/index.html
Let me know if you have additional concerns or e-mail (adawa@cisco.com) me directly. Kind regards.
10-19-2014 11:05 AM
There is also a 2U 96 port Nexus 5k switch.
