Cisco Fibre SFP to Netgear firbe port
If I want to connect a Cisco Fibre 1 gig SFP port to a simple Netgear FSP port will it work?
The above works when i use a CAT 5 connection.
Many thanks.
Mike
1 ACCEPTED SOLUTION
Re: Cisco Fibre SFP to Netgear firbe port
It should work with out any problem if both the ports are using the standard based technology.On the Cisco side, just run the command " speed no negotiate" under the interface.
HTH,
-amit singh
1 REPLY
HTH,
-amit singh
998
