05-28-2014 09:46 PM - edited 03-07-2019 07:34 PM
Hello, please help with solving problem
IP Phone are connected to catalyst WS-C6509-V-E
The configuration is
interface GigabitEthernet1/1/47
switchport
switchport access vlan 101
switchport mode access
switchport voice vlan 201
spanning-tree portfast edge
end
#sh cdp nei GigabitEthernet1/1/47
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID Local Intrfce Holdtme Capability Platform Port ID
SEP001E136C5C67 Gig 1/1/47 175 H P M IP Phone Port 1
But
#sh mac add int GigabitEthernet1/1/47
Legend: * - primary entry
age - seconds since last seen
n/a - not available
S - secure entry
R - router's gateway mac address entry
D - Duplicate mac address entry
Displaying entries from active supervisor:
vlan mac address type learn age ports
101 001e.136c.5c67 dynamic Yes 150 Gi1/1/47
these phone are working fine on catalyst 3750 with same configuration both port and IP Phone (6509 is core switch, 3750 is access switch)
05-28-2014 11:39 PM
remove the switchport mode access statement
05-29-2014 12:59 AM
Done
#sh int gi1/1/47 sw
Switchport: Enabled
Administrative Mode: dynamic desirable
Operational Mode: static access
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: native
Operational Dot1q Ethertype: 0x8100
Negotiation of Trunking: On
Access Mode VLAN: 101 (USR1)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Operational Native VLAN tagging: disabled
Voice VLAN: 201 (VOC1)
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
#sh run int gi1/1/47
Building configuration...
Current configuration : 135 bytes
switchport
end
Just the same
n/a - not available
S - secure entry
101 001e.136c.5c67 dynamic Yes 100 Gi1/1/47
