Cisco Netflow Configuration on 3750
Hello Community,
Can someone please tell me why I can't apply the following Netflow configurations to our 3750s
flow record FlowRecord1
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
match interface input
collect interface output
collect flow direction
collect counter bytes
collect counter packets
collect timestamp sys-uptime first
The show version of the 3750 are as follows:
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(55)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 09-Feb-12 18:14 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02800000
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(53r)SE2, RELEASE SOFTWARE (fc1)
MX-C3750-FL1-N uptime is 18 weeks, 4 days, 3 hours, 14 minutes
System restarted at 11:47:29 UTC Sat Apr 27 2013
System image file is "flash:/c3750e-universalk9-mz.122-55.SE5/c3750e-universalk9-mz.122-55.SE5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3750X-48P (PowerPC405) processor (revision K0) with 262144K bytes of memory.
Processor board ID FDO1702Z2R1
Last reset from power-on
3 Virtual Ethernet interfaces
1 FastEthernet interface
208 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
Cheers
Carlton
9 Replies 9
cadet alain
"Only the Cisco 3750 X series and 3560 X series with new NetFlow service module (
C3KX-SM-10G )supports complete flexible NetFlow export for Uplink ports. "
Alain
Hi Cadet
Thanks for responding.
Can you advise what Netflow Service Module we would need to purchase?
Cheers mate
Cadet,
We also have the following device that doesn't appear to support Netflow. Can you advise on the the service module we would need?
MX-WAN-R02#show ver
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-ENTSERVICESK9-M), Version 12.2(54)SG1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 27-Jan-11 12:07 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x12E16D24
ROM: 12.2(44r)SG10
Sushi Revision 11, Tatooine Revision 141, Forerunner Revision 1.78
MX-WAN-R02 uptime is 40 weeks, 4 days, 17 minutes
System returned to ROM by reload
System restarted at 14:10:42 GMT Sat Nov 24 2012
System image file is "bootflash:cat4500e-entservicesk9-mz.122-54.SG1.bin"
export@cisco.com.
cisco WS-C4900M (MPC8548) processor (revision 2) with 1048576K bytes of memory.
Processor board ID JAE1632077X
MPC8548 CPU at 1.33GHz, Cisco Catalyst 4900M
Last reset from Reload
18 Virtual Ethernet interfaces
36 Gigabit Ethernet interfaces
16 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Cheers mate
That's brilliant mate.
I will take that to my boss in the morning.
Cheers
Cadet,
If my boss would like to see alternatives to purchasing a service module, can you think of any other ways we could monitor traffic flowing across our 3750 or 4500 without purchasing a Netflow Services Module?
Cheers
Hi Carlton,
yes it is possible. here's one solution here:http://thwack.solarwinds.com/thread/24243
Alain
Hi Cadet,
Thanks again for getting back to me.
I'm looking at the link you provided above. While I was reading I saw the following statement:
The only Cisco switches that support Netflow are the  4500 and 6500 series switches
However, our 4500 L3 switch won't support netflow. Is there any reason why?
We also can't configure span port on the switch :-(
it doesn't support flexible Netflow(v9) but surely regular Netflow. Here's a note concerning SPAN on the 4500 switch:http://thwack.solarwinds.com/thread/24243
Alain
