04-14-2014 06:51 AM - edited 03-07-2019 07:05 PM
Hi all,
Hi have install a cisco nexus 7010 with the following modules :
Mod Ports Module-Type Model Status
1 48 1000 Mbps Optical Ethernet XL Modul N7K-M148GS-11L ok
2 48 10/100/1000 Mbps Ethernet XL Module N7K-M148GT-11L ok
5 0 Supervisor Module-2 N7K-SUP2 active *
6 0 Supervisor Module-2 N7K-SUP2 ha-standby
9 48 10/100/1000 Mbps Ethernet XL Module N7K-M148GT-11L ok
10 48 1/10 Gbps Ethernet Module N7K-F248XP-25E ok
After trying to build a port-channel with a 1G port on slot 1 and a 1G port on slot 10 i get a messague with incompatible port.
Can any one tell me if its supported a port-channel with ports on the following modules :
N7K-M148GS-11L
N7K-F248XP-25E
Patrício
Solved! Go to Solution.
04-14-2014 07:54 AM
Hi Particio,
The port-channel/vPC features require that all uplinks are connected to the same type of
module. You can refer to the following document.
http://www.cisco.com/en/US/partner/docs/switches/datacenter/sw/6_x/nx-os/interfaces/configuration/guide/if_portchannel.html#wp1888267
Inayath
*Plz rate if this is helpfull and mark as Answerd if this answerd your query.
04-14-2014 07:43 AM
Hi Patricio,
According to the docs:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/5_x/nx-os/interfaces/configuration/guide/if_cli/if_portchannel.html#wp1798353
Ports from these line cards will no be able to join the same port-channel becuase of a '(Link) speed capability' mis-match (1000 vs 1000/10,000).
cheers,
Seb.
04-14-2014 08:08 AM
Hi All,
After searching i found that is not possible to bundle interfaces from M1-XL and F2 module
thanks to all,
Patricio
04-14-2014 08:12 AM
Hi Patricio,
If our answer helped you could you please do a favour of marking the rating and select the option of Correct Answer so that we close this thread?
thanks in advance.
REgards
Inayath
04-14-2014 07:54 AM
Hi Particio,
Inayath
