Cisco Nexus 7010 Port-Channel
Hi all,
Hi have install a cisco nexus 7010 with the following modules :
Mod  Ports  Module-Type                         Model              Status
1    48     1000 Mbps Optical Ethernet XL Modul N7K-M148GS-11L     ok
2    48     10/100/1000 Mbps Ethernet XL Module N7K-M148GT-11L     ok
5    0      Supervisor Module-2                 N7K-SUP2           active *
6    0      Supervisor Module-2                 N7K-SUP2           ha-standby
9    48     10/100/1000 Mbps Ethernet XL Module N7K-M148GT-11L     ok
10   48     1/10 Gbps Ethernet Module           N7K-F248XP-25E     ok
After trying to build a port-channel with a 1G port on slot 1 and a 1G port on slot 10 i get a messague with incompatible port.
Can any one tell me if its supported a port-channel with ports on the following modules :
N7K-M148GS-11L
N7K-F248XP-25E
Patrício
1 ACCEPTED SOLUTION
Hi Particio,The port-channel
Hi Particio,
The port-channel/vPC features require that all uplinks are connected to the same type of
module. You can refer to the following document.
http://www.cisco.com/en/US/partner/docs/switches/datacenter/sw/6_x/nx-os/interfaces/configuration/guide/if_portchannel.html#wp1888267
Inayath
*Plz rate if this is helpfull and mark as Answerd if this answerd your query.
Hi Patricio,According to the
Hi Patricio,
According to the docs:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/5_x/nx-os/interfaces/configuration/guide/if_cli/if_portchannel.html#wp1798353
Ports from these line cards will no be able to join the same port-channel becuase of a '(Link) speed capability'  mis-match (1000 vs 1000/10,000).
cheers,
Seb.
 Hi All, After searching i
Hi All,
After searching i found that is not possible to bundle interfaces from M1-XL and F2 module
thanks to all,
Patricio
Hi Patricio,If our answer
Hi Patricio,
If our answer helped you could you please do a favour of marking the rating and select the option of Correct Answer so that we close this thread?
thanks in advance.
REgards
Inayath
Hi Particio,
Inayath
87
