Cisco router 2500 and ADSL
I want to configure Cisco router 2500 to used with ADSL line , how can I accomplish this while the I am using Router/modem in the front ,,can I use EIGRP configuration on the cisco router to advertise the internal real network.
1 REPLY
Silver
Re: Cisco router 2500 and ADSL
If you are suing a router you can definitely use EIGRP. If the number of networks are not large and if the network can be manually managed you can also go with Static routing.
336
