Cisco Router 3745 - Crypto ISAKMP Policy command not working
Hi, I have Cisco 3745 Router and trying to execute the command Cryptop isakmp policy, but command not accepting and says invalid input detected.
Below is the show version, please suggest, if how do i achieve this.
Cisco IOS Software, 3700 Software (C3745-SPSERVICESK9-M), Version 12.4(25d), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 18-Aug-10 08:18 by prod_rel_team
ROM: System Bootstrap, Version 12.2(8r)T2, RELEASE SOFTWARE (fc1)
VSOFT_Hydreabad uptime is 25 minutes
System returned to ROM by reload
System image file is "flash:c3745-spservicesk9-mz.124-25d.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3745 (R7000) processor (revision 2.0) with 112640K/18432K bytes of memory.
Processor board ID JPE071410VY
R7000 CPU at 350MHz, Implementation 39, Rev 3.3, 256KB L2, 2048KB L3 Cache
2 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity disabled.
151K bytes of NVRAM.
62592K bytes of ATA System CompactFlash (Read/Write)
MAC
Regards MAC
Re: Cisco Router 3745 - Crypto ISAKMP Policy command not working
I believe you are missing advance security feature / advance ip services which include IPSec feature. Other plz correct me if I am wrong
Hall of Fame Super Silver
I believe that this answer is exactly correct. So +5.
I checked the feature navigator from the Cisco site looking for this IOS image and find that it does not have support for crypto isakmp. Mac asks how to achieve the configuration. I would say that upgrading to the feature set that does support crypto isakmp would be the solution. I checked the software download page and it shows that software is still available for the 3745 so a feature set upgrade should be feasible.
Rick
VIP Purple
This is from IOS-Packaging
http://www.cisco.com/en/US/products/sw/iosswrel/ps5460/products_qanda_item09186a00801af2c6.shtml
http://www.cisco.com/image/jpg/en/us/guest/products/ps5460/c1167/ccmigration_09186a00801af2c6_09186a0080843375-5.jpg
It's always good to remember how the old feature-sets relate to each other.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Don't stop after you've improved your network! Improve the world by lending money to the working poor: http://www.kiva.org/invitedby/karsteni
1732
