Cisco Router Password Recovery In Brief
What are the commands to recover the password of a cisco router?
Please explain in short.
is the procedure different for different series of routers?
Re: Cisco Router Password Recovery In Brief
The procedure is same for almost all Cisco routers. Here is the example :
http://www.cisco.com/en/US/products/hw/routers/ps380/products_password_recovery09186a00800942bc.shtml#procedure
For all Cisco Devices check here,
http://www.cisco.com/warp/public/474/index.shtml#routers
Yes.. it is slightly different for lower end and higher end router models. The below link gives you information for varous routers & Switches.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00801746e6.shtml
MS
Mostly the process for password resets are the same although
some switches like the 3560 have a mode button you hit instead of page break as the switch boots up to enter rommon
Here is a straight forward instructions....
step by step
http://www.learnios.com/viewtopic.php?f=72&t=28
184
