Cisco RPS
We are planning to deploy a Cisco RPS 2300 with 3 x 2960-48 and 1 x 3750-48 and 1 x 3750G-12.
Looking at the Cisco RPS, I can see that it can only connect 4 devices. Here I have 5 devices. How will this work?
Also I am thinking if we go quasi redundant, does that mean, I have to re specify the request of the switches so that they are RPS compatible?
1 REPLY
Hall of Fame Super Bronze
Re: Cisco RPS
The Cisco RPS 2300 allows you to connect up to 6 switches but only provides power to 2 active switches in an event of a power supply failure.
The switches listed above are supported on this model.
For more information, I recommend reading this presentation:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps7148/ps7130/prod_presentation0900aecd805bbf15.pdf
HTH,
__
Edison.
130
