Cisco's expert plz help
Hello and PLZ Help Me
I tried to console to a VPN C 3005 using RS 232 cable with 2 DB 9 Female at both side (PC/SERIAL)-(VPN/CONSOLE) and Tuning Terminal Settings as Cisco described although I've attached to cat 5 cable to each interfaces (private-public) with green Light on interface led and system led also….so what's the problem ?I m Confused
thanks
Re: Cisco's expert plz help
any help here
Hall of Fame Super Bronze
Ali,
You may want to ask in the VPN forum as this query does not address any routing and switching component.
__
Edison
hello edison
its being long time..how r y?i hope y doing well...man i post there but i didn't get any good response there..anyways the VPN C Has a problem with console port
Thank y
Ali,
I'm doing well, thanks for asking. It has been a long time indeed and I'm glad to see you around.
The only thing I can recommend is checking this link:
http://supportwiki.cisco.com/ViewWiki/index.php/How_to_connect_to_the_VPN_3005_Concentrator_via_a_console_cable
http://supportwiki.cisco.com/ViewWiki/index.php/The_user_cannot_connect_to_the_console_port_of_the_VPN_Concentrator_3005
If that fails, contact TAC for assistance.
HTH,
__
Edison.
123
