Community Member
cisco sge2000p with uc520 voic
I have a sge2000p to install with a uc520. I have all data traffic passing ok but voice will not work. Phones to not get ip etc. can anyone advise?
1 ACCEPTED SOLUTION
Green
Hi Jonathan,
The SGE2000 is not a particularly good voice switch. It does not support CDP or LLDP-MED and does not have telephony OUI options nor a voice vlan or smart ports / macros.
This means you need to manually configure all of the ports for the data vlan untag, voice vlan tag and ensure your uplink to the UC has the correct trunk and tag as well.
Quite honestly, if you're looking for a small business solution, go with a SG300-24P  (srw2024-k9) switch. It will make your life a heck of a lot easier.
-Tom
Please rate helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Green
Hi Jonathan,
-Tom
Community Member
Re: cisco sge2000p with uc520 voic
Yes I have no choice a customer purchased them. Took your advice and works perfectly for my needs. Thanks
Community Member
Hi, did you have to configure the phones with the vlan configuration for them to pickup the right voice network ?? what type of phones where you using ?
thanks.
Community Member
No it was all automatic.
I first plugged phone to uc520 and assigned extn etc. Then moved to switch.
Then did this on switch
I think I set all ports as trunk ports. Not particularly good practice but works!
347
