01-14-2010 08:47 AM - edited 03-06-2019 09:17 AM
Says it is unamanaged switch. Does this mean I can't put any configuration on it? If I can, how can I connect to it?
01-14-2010 08:53 AM
ccie_rooky wrote:Says it is unamanaged switch. Does this mean I can't put any configuration on it? If I can, how can I connect to it?
ccie_rooky wrote:
Yes, that's exactly what it means ie. you don't configure it, you just plug it into your network and off you go.
Jon
01-14-2010 09:25 AM
Thanks Jon.
