Cisco Supervisor 7L-E USB Port is not working
mlinder01
Nothing happens when we plug a USB Flash Drive into an SUP7L-E USB port. Does anybody know if this works?
Manuel
Edison Ortiz
Then this should work :
« A standard USB 2.0 device such as a flash memory device can plug into this connector. »
Is there only a specific typ supported ?
Manuel
Von: ediortiz
Gesendet: Mittwoch, 2. Mai 2012 16:22
An: Linder Manuel (CASSARiUS AG)
Betreff: - Re: Cisco Supervisor 7L-E USB Port is not working
Home<>
created by Edison Ortiz<> in LAN, Switching and Routing - View the full discussion<>
Try formatting the USB with FAT32.
Leo Laohoo
Yes it will work and it will depend entirely on the following factors:
1.  NOT ALL USB are supported.  The best way to check is insert the USB stick and perform the command "sh log".  If you get the log entry in the words like "USB inserted" and nothing negative then it's going to work;
2.  Format using FAT16;
3.  Sup7?  I didn't have the chance to test but it should support up to 8 to 16 Gb size USB sticks.
