Cisco switch 2960 - 7port - POE issue
mfouad.jahmi
hi,
when am trying to plug a PC into the switch, it takes power as the switch is POE . but when trying to plug IP Camera Device it does not take any power.
although i have cisco 2960 - 24 ports both PC and IP Camera getting power. while troublshooting by #show power inline , i get nothing as well.
dwtc-edge2960-7-1st#show power inline
  GigabitEthernet  GigabitEthernet IEEE 802.3z
  consumption      Show inline power consumption
  |                Output modifiers
  <cr>
dwtc-edge2960-7-1st#show power inline consumption
Interface  Consumption      Admin
           Configured    Consumption (Watts)
Available:0.0(w)  Used:0.0(w)  Remaining:0.0(w)
Interface Admin  Oper       Power   Device              Class Max
                            (Watts)
any advice !!?
MJ
6 Replies 6
jimmysands73_2
Level 5
Level 5
First question:
How does your PC get power?  I dont understand why a PC needs POE.
Second:
Your port configs doesnt have it turned POE do they?
From http://www.cisco.com/en/US/products/hw/switches/ps4324/products_configuration_example09186a0080722cdb.shtml
Switch(config-if)# power inline auto
   auto         Automatically detect and power inline devices
Make sure that yuou are using a known working POE device when testing.  Also try a nonPOE device to make sure the port atleast becomes up/up.
Third:
When you do debug while plugging in a capable POE device what does it say?
Handy docs:
Troubleshooting Power over Ethernet (PoE)
(diff platform, same exact principle)
Message was edited by: Jimmy Sands More reference Configuration Note for Catalyst 2960 Switch Power over Ethernet Ports, Rel. 12.2(44)SE http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_44_se/configuration/note/ol14988.html
Leo Laohoo
Can you please post the complete output for the command "sh version"?
jimmy,
i followed your advice but  i cant Use the power inline interface configuration command to configure the power management mode on the Power over Ethernet (PoE) ports.
when am trying to allocate power inline under the interface, am not able to get the following commands :
#power inline {auto [max max-wattage] | never | static [max max-wattage]}
or
#logging event power-inline-status
Is that due a software version which not supported those commands ?
leo,
pls look at the sh ver output >>>
dwtc-edge2960-7-1st#show version
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 12.2(50)SE4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 26-Mar-10 09:14 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01400000
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(35r)SE2, RELEASE SOFTWARE (fc1)
dwtc-edge2960-7-1st uptime is 14 minutes
System image file is "flash:c2960-lanbasek9-mz.122-50.SE4/c2960-lanbasek9-mz.122-50.SE4.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960G-8TC-L (PowerPC405) processor (revision C0) with 65536K bytes of memory.
Processor board ID FOC1504W3BW
Last reset from power-on
2 Virtual Ethernet interfaces
8 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 44:E4:D9:62:67:00
Motherboard assembly number     : 73-10613-08
Power supply part number        : 341-0208-02
Motherboard serial number       : FOC15031MKT
Power supply serial number      : LIT15010964
Model revision number           : C0
Motherboard revision number     : B0
Model number                    : WS-C2960G-8TC-L
System serial number            : FOC1504W3BW
Top Assembly Part Number        : 800-28133-02
Top Assembly Revision Number    : E0
Version ID                      : V02
CLEI Code Number                : COM7S00ARB
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 8     WS-C2960G-8TC-L    12.2(50)SE4           C2960-LANBASEK9-M
Configuration register is 0xF
MJ
Hi Mohamad, how are you doing?
What is the model for the 24-port 2960? Seems like the the model you sent the sh ver (WS-C2960G-8TC-L) doesn't support PoE. As I found in this link. Look at table 14:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/product_data_sheet0900aecd80322c0c.html
Also you can see a comparision between 2960 models on this URL:
http://www.cisco.com/en/US/products/ps6406/prod_models_comparison.html
Vitor
Vitor,
thanks for you assitance, your post were really useful to me.
the switch model is  WS-C2960G-8TC-L  which is Cisco Catalyst 2960-8TC-L.
i tracked the link attached and found that there is no POE mentioned .
does this mean the switch not supported POE ?
That's not a PoE switch.  It won't support PoE.
You have but three choices:
1.  If an 8-port PoE switch is what you need then consider the WS-C3560-8PC; or
2.  Get power injectors for the power devices; or
3.  Get a mid-span switch.
