Community Member
Cisco Switch 2960 S
I am currently doing an apprenticeship in a business here in France. They are using Cisco equipment ONLY. They have about 60 switches and they are doing some work to make the network bigger.... I am looking into the Cisco Switch 2960S and read many documents on CISCO website and others. This is very good.
I have read a french document from Cisco France (I think) on how to set up flexstack. This is also interesting and I had some questions which I found the answer for BUT I still have one or two unanswered.
1. When the 2 or 3 switch are connected with flexstack, I understood that one of them is the master and the others are the members. My question is : when you have 2 switches connected that way, when you go into configuring the switch ports, do you then see 48 ports (when you have connected 2x 2960S 24ports) ?
2. if the master goes down, then everything goes down, which will make sense, isn't it ? and the reason it is recommended to have a master as a spare ready. But how do you configure the spare in advance if he doesn't see the other switches ? Do you then configure your 2 or 3 switches, then do a copy of the configuration and download it to the spare one ahead of time ?
3. Do you have any PDF docs you may think will help me with all of this ?
Hopefully, you understand what I am asking for as I am a poor french man !!!
Manu
1 ACCEPTED SOLUTION
Re: Cisco Switch 2960 S
Hi Manu,
Your underhanding is correct.
1, you will see 48 ports, 24 ports for each slot.
2, Yes, you can manually configure a backup master by assigning the priority to the member switch.
3,http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/white_paper_c11-578928.html
HTH,
Lei Tian
Hi Manu,
HTH,
Lei Tian
Community Member
Thanks so much.
Manu
487
