Community Member
Cisco Switch 3560G PoE-24 not booting
Dear All
i facing problem with my switch cisco 3560G, when it power on only System light is green and noting happen.  i check with serial cable ( Console) but noting happen  no booting. any body have any idea the reson of this or it flash problem
Nasser Aziz
Everyone's tags (1)
Hall of Fame Super Blue
Have you tried another client to verify your console connection?
Do you get garbage character when you console into the switch?
Community Member
Re: Cisco Switch 3560G PoE-24 not booting
i tried putty , tera term , secure crt none of them show any single character, the console cable is ok and its work with other switch .
i think it maybe Flash or Hardware failure. if booting at least should be show some character or go to ROM mode but noting happend.
540
