Cisco Switch and Router connection
soorajn2011
Hello all,
I have a router cisco 2921 and a switch 2924. Both are configured. My issue is when we use a network monitoring tool discovery, it doesn't show the switch. I am attaching both router and switch sh run output. Please let me know in case of any issues
Any help would be appreciable
daniel.dib
Level 7
Level 7
Which NMS are you using? Does it use SNMP? Have you tried SNMP walking the device manually? Can you ping the router from the switch? Can you ping the NMS from the switch?
Daniel Dib
CCIE #37149
Please rate helpful posts.
Daniel Dib
CCIE #37149
CCDE #20160011
11 Replies 11
daniel.dib
Level 7
Level 7
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
But I have one more issue. All the linux machine under this router is not getting internet. Please help me on this
ip dhcp pool LAN
network 192.168.1.0 255.255.255.0
You don't send the default-gateway to your clients, so add this under dhcp pool: default-router 192.168.1.1
Alain
I am giving the command default-router 192.168.1.1. But againt i didnt get internet in linux machine. But before giving this command als, i am getting internet to all my windows machine. I gave a static IP to the linux machine 192.168.1.149. Also I cant ping the default gateway 192.168.1.1 from any of the linux machine.
Pleasde help
Thanks in advance
Sooraj N
That's strange. You didn't have default-router and also no name server handed out on your DHCP pool.
Can you do a ipconfig /all on a Windows machine.
Did the Linux client not receive DHCP? Did you set a default gateway on it? You should still be able to ping 192.168.1.1 though.
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
if your clients( windows and linux) are in same vlan they should get the dhcp parameters and so communicate with outside world as they have a default-gateway and the router is doing nat overload.
So first can you ping 8.8.8.8 from your router ?
if so do your clients receive correct settings from the dhcp server(router) ? --->
ipconfig/all on windows and ifconfig on linux
can you ping your default gateway from clients and if not do you have arp entry for the default-gateway in arp cache
---> arp command
once you can ping default-gateway we'll investigate why you can't go to internet from clients
Alain
One thing I forgot to mention is all the machines both windows and linux are in static IP. Also I can ping 8.8.8.8 from my router. Some times i can't find the issues. its working fine sometimes
You mean sometimes you can ping 8.8.8.8 from client and sometimes not ?
Can you post sh ip nat translation | i x.x.x.x  where x.x.x.x is the client IP when not working
alain
No result for that command
you mean you do your ping to 8.8.8.8 from client and this command outputs nothing ?
Then you have a problem with your nat config
post client config, result of ping and  the sh ip nat translation command you did along with output.
Alain
Hello all,
I have the internet issue with linux machine only. all the other windows machine getting internet. Also I cant ping the default gateway 192.168.1.1 from my linux machine and also no able to ping linux machine from router. Some times i can ping.
Please help me out this
