cisco switch WS-C3750X-48T # CPU UTILIZATION ISSUE
Dear All,
I have a cisco switch WS-C3750X-48T .During the operation of this switch i have the issue of high cpu utilization .
please suggest the major reason due to which the switch behave like this and what is the problem with switch.
please find the attached log ....
UG-GW-CORE#sh proc cpu | e 0.00
CPU utilization for five seconds: 34%/1%; one minute: 36%; five minutes: 36%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
  10      833688   1686490        494  0.31%  0.71%  0.63%   0 ARP Input
  69      144766     30391       4763  0.15%  0.13%  0.11%   0 Compute load avg
  74     4470389    735065       6081  2.86%  2.75%  2.77%   0 RedEarth Tx Mana
  80     1068811     60462      17677  0.79%  0.70%  0.65%   0 Adjust Regions
116     2567337    295705       8682  1.58%  1.55%  1.56%   0 hpm counter proc
156    24497604   2908539       8422 15.57% 14.80% 14.65%   0 Hulc LED Process
167      546741     30415      17976  0.31%  0.31%  0.31%   0 HQM Stack Proces
198      604538   1052522        574  0.31%  0.58%  0.55%   0 IP Input
217     8967911   1674951       5354  6.04%  5.16%  5.23%   0 Spanning Tree
Madhuraj,
Most of the IOS images on this platform have this bug, and even if you upgrade you might see the same issue again.
So as a workaround to reduce the CPU consumption of this process, go ahead and shut down all unused interfaces, and it might bring down the CPU consumed due to HULC LED little bit.
The High CPU consumption because of HULC LED process won't imact your network at all.
Ankur
"Please rate the post if found useful"
Jose Solano
Level 4
Level 4
This issue can be due to Hulc LED Process:
Hulc LED Process - Is responsible for link status detection.
Symptom:
Hulc LED Process uses 15-30% CPU on Catalyst 3560X/3750X platforms.
Conditions:
The is seen in 12.2(53)SE releases or later.
Workaround:
This is an expected behavior and there is no workaround.
Further Problem Description:
The "Hulc LED" process does following tasks:
- Check Link status on every port
- If the switch supports POE, it checks to see if there is a Power Device (PD) detected
- Check the status of the transceiver
- Update Fan status
- Set Main LED and ports LEDs
- Update both Power Supplies and RPS
- Check on system temperature status
Bug details at :
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtn4279
Hence, this is expected behavior and you should not worry about it. As per what I can see your switch has a 34% of cpu usage which should not cause any issues, it is normal.
Hope this helps, and remember to rate any useful posts.
Hi Leo ,
Thanks for your answer ....
Current IOS version is      12.2.(55) SE
please suggest with good one ......
Message was edited by: Madhuraj singh kushwah
Madhuraj,
Ankur
Thanks Ankur ,
Now the switch cpu utilization has reduced up to 15 %
now it is 25 % from 36%
Can I further reduced it .the cpu utilization is given below.
There is one more concern that i have configure the access list on switch in which i get logs for every packet.
if i disable the log on switch then can it will work so that cpu utilization reduce....
the logs is mention below-----
UG-GW-CORE#sh processes cpu | e 0.00
CPU utilization for five seconds: 27%/0%; one minute: 25%; five minutes: 25%
  10     2011986   3778260        532  0.63%  0.78%  0.76%   0 ARP Input
  38      115380    336632        342  0.15%  0.10%  0.10%   0 Per-Second Jobs
  39      178717      5727      31206  0.63%  0.07%  0.01%   0 Per-minute Jobs
  73      761745   2470458        308  0.63%  0.51%  0.49%   0 RedEarth I2C dri
  74     9815543   1633880       6007  2.55%  2.76%  2.72%   0 RedEarth Tx Mana
  80     2406932    134778      17858  0.63%  0.65%  0.65%   0 Adjust Regions
  83      217118   1048444        207  0.15%  0.07%  0.05%   0 hrpc <- response
  96      282851   9460989         29  0.47%  0.28%  0.27%   0 HLFM address lea
116     5782765    658830       8777  1.59%  1.68%  1.65%   0 hpm counter proc
156    47830340   6784646       7049  4.63%  4.48%  4.58%   0 Hulc LED Process
157      137114    248278        552  0.15%  0.07%  0.05%   0 HL3U bkgrd proce
167     1220864     67698      18033  0.47%  0.40%  0.36%   0 HQM Stack Proces
168      432016    270478       1597  0.15%  0.15%  0.15%   0 HRPC qos request
186      922785    329956       2796  2.55%  0.37%  0.27%   0 CDP Protocol
198     1819965   2655418        685  0.95%  1.07%  1.00%   0 IP Input
204      311684   1261478        247  0.47%  0.23%  0.21%   0 ADJ resolve proc
217    14968786   5172271       2894  2.71%  2.70%  2.88%   0 Spanning Tree
253      128390    256773        500  0.15%  0.04%  0.03%   0 TCP Protocols
317      137640    523279        263  0.15%  0.13%  0.11%   0 CEF: IPv4 proces
343      249372   1969676        126  0.31%  0.17%  0.16%   0 EIGRP-IPv4 Hello
348          92       178        516  0.31%  0.12%  0.03%   2 Virtual Exec
UG-GW-CORE#sh loggin
Syslog logging: enabled (0 messages dropped, 0 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: level debugging, 795 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 6 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 795 messages logged, xml disabled,
                     filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    File logging: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level informational, 808 message lines logged
        Logging to 10.10.10.66  (udp port 514,  audit disabled,
              authentication disabled, encryption disabled, link up),
              808 message lines logged,
              0 message lines rate-limited,
              0 message lines dropped-by-MD,
              xml disabled, sequence number disabled
              filtering disabled
Log Buffer (4096 bytes):
ted 10.11.35.103 302 packets
.Jan 27 10:26:32.934 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 298 packets
.Jan 27 10:31:33.559 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 298 packets
.Jan 27 10:36:34.561 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 300 packets
.Jan 27 10:41:35.084 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 298 packets
.Jan 27 10:46:35.700 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 300 packets
.Jan 27 10:51:36.358 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 298 packets
.Jan 27 10:56:36.974 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 298 packets
.Jan 27 11:01:37.783 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 300 packets
.Jan 27 11:06:38.365 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 298 packets
.Jan 27 11:11:39.006 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 300 packets
.Jan 27 11:16:39.647 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 298 packets
.Jan 27 11:21:40.574 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 298 packets
.Jan 27 11:26:41.072 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 300 packets
.Jan 27 11:31:41.705 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 300 packets
.Jan 27 11:36:42.363 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 300 packets
.Jan 27 11:41:43.247 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 298 packets
.Jan 27 11:43:30.958 IST: %SYS-5-CONFIG_I: Configured from console by ugamnet on vty1 (10.11.35.103)
.Jan 27 11:44:38.318 IST: %SYS-5-CONFIG_I: Configured from console by ugamnet on vty1 (10.11.35.103)
.Jan 27 11:46:43.888 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 298 packets
.Jan 27 11:51:44.504 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 300 packets
.Jan 27 11:56:45.145 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 298 packets
.Jan 27 12:01:45.770 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 300 packets
.Jan 27 12:06:46.377 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 298 packets
.Jan 27 12:11:46.976 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 298 packets
.Jan 27 12:16:47.567 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 300 packets
.Jan 27 12:21:48.393 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 298 packets
.Jan 27 12:24:21.796 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.10.8.65 1 packet
.Jan 27 12:26:48.841 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 298 packets
.Jan 27 12:29:49.189 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.10.8.65 1 packet
.Jan 27 12:31:49.440 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 300 packets
.Jan 27 12:34:49.754 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.10.8.65 2 packets
.Jan 27 12:36:49.989 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 298 packets
.Jan 27 12:41:50.865 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 300 packets
.Jan 27 12:46:51.355 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 298 packets
.Jan 27 12:51:51.963 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 298 packets
.Jan 27 12:56:52.570 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 300 packets
.Jan 27 13:01:53.161 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 298 packets
.Jan 27 13:06:53.777 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 298 packets
.Jan 27 13:11:54.359 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 300 packets
.Jan 27 13:16:55.227 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 298 packets
.Jan 27 13:21:55.784 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 300 packets
.Jan 27 13:26:56.392 IST: %SEC-6-IPACCESSLOGS: list access-in permitted 10.11.35.103 298 packets
