cisco switches model inquiry
hi i would like to ask what are these E, L, S, W-S which is in the last portion of the model of cisco?
VIP Super Bronze
L is for LAN baseS is IP
L is for LAN base
S is IP Base
P for POE
E for IP services and so on.
See table-17 in this link for more info
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3850-series-switches/data_sheet_c78-720918.html
hi, the link says page not
hi,
the link says page not found
thanks
Both the links are working
Both the links are working fine could you recheck; make sure you copy entire http address:
b)
http://www.cisco.com/c/en/us/products/switches/catalyst-3850-series-switches/models-comparison.html
Inayath
hi may i ask what are these
hi may i ask what are these UPLINK? are these the gbic module?
thanks
uplink were you can insert
uplink were you can insert the SFP modules.
Can u try the link again:
L-- Lan Base modes.
S -- Ip Base software models.
E -- Ip Services
Inayath
56
