11-10-2013 07:31 AM - edited 03-07-2019 04:31 PM
We we have an office which is using a hosted IP provider but they just have 15 x non Cisco desk VOIP phones and have their PC's plugged into them all on VLAN 1.
I've created 2 VLANs there, 1 for Data and the other for Voice, would I just need to make the switch ports a trunk and set the phones to the voice vlan?
Any example port configs woud lbe great. They don't have QoS either which I may add.
11-10-2013 07:56 AM
Hi Andy,
Please find the configuration below. It should work fine without any issues.
vlan 301
name Data
vlan 309
name VoIP
lldp run
interface FastEthernet0/9
description PC & IP Phone
switchport trunk native vlan 301
switchport trunk allowed vlan 301,309
switchport mode trunk
spanning-tree portfast trunk
spanning-tree bpduguard enable
Thanks & regards,
Karthick Murugan
CCIE#39285(R&S)
11-10-2013 08:02 AM
That is how I did it, the only thing I have missing is "lldp run" what is that?
11-10-2013 08:08 AM
Hi Andy,
I am very glad that you got the configuration right.
LLDP is a replacement for CDP.
CDP is to detect the neighbor device(Cisco) and LLDP can be used for Avaya.
Karthick Murugan
11-10-2013 11:53 AM
Just one thing I noticed I didn't use the "switchport trunk native vlan x" would this be for anything untagged?
11-10-2013 05:24 PM
"switchport trunk native lan x" is the replacement for "switchport access vlan x" in both the cases the VLAN will not be tagged.
Karthick Murugan
