Community Member
cisco uc540 falla
Buen dia tengo un conmutador cisco uc540 y me marca este error y no arranca configuracion alguien me puede ayudar a restaurarlo
System Bootstrap, Version 12.4(24r)SB, RELEASE SOFTWARE (fc1)
Copyright (c) 2009 by cisco Systems, Inc.
UC500 series platform with 262144 Kbytes of main memory
Readonly ROMMON initialized
program load complete, entry point: 0x80015000, size: 0xb700
program load complete, entry point: 0x80020000, size: 0x280c288
Self decompressing the image : ##################################################################################################################################################################################################################################################################################################################################################################################################################### [OK]
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
0X00063E08 Onboard Wireless
0X00137430 Onboard PVDM2 SIMM
0X00118500 Onboard Ethernet
0X00128800 Onboard VPN
0X000F3BB0 public buffer pools
0X00703000 public particle pools
TOTAL: 0X00BD2AE8
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 11Mb.
adjusted iomem size up to minimum size of: 0X01A00000
Using 10 percent iomem. [26Mb/256Mb]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 15.1(4)M4b, CIBU Special
Small Business Support: http://www.cisco.com/go/smallbizhelp
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Fri 18-May-12 15:06 by CIBU
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco UC540W-FXO-K9 (MPC8358) processor (revision 0x100) with 235520K/26624K bytes of memory.Installed image archive
Processor board ID FGL162926BL
MPC8358 CPU Rev: Part Number 0x804A, Revision ID 0x20
30 User Licenses
10 FastEthernet interfaces
2 terminal lines
1 Channelized (E1 or T1)/PRI port
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
4 Voice FXS interfaces
1 Voice MoH interface
1 802.11 Radio
1 cisco service engine(s)
128K bytes of non-volatile configuration memory.
250880K bytes of ATA CompactFlash (Read/Write)
Uncompressed configuration from 73735 bytes to 175206 bytes
no logging discriminator
% Incomplete command.
Logging of %SNMP-3-AUTHFAIL is disabled
logging queue-limit esm 0
% Invalid input detected at '^' marker.
logging buffered 0 debugging
ipc holdq threshold upper 0
ipc holdq threshold lower 0
port 1645
port 1700
clock summer-time CDT recurring 60
cef table vrf tree IPv6 type RTREE
cef table output-chain build favor default
no ip cef accounting
ip nbar port-map h323 tcp 1300 1718 1719 1720 11000 - 11999
ip nbar port-map custom-10 udp
ip nbar port-map custom-10 tcp
ip nbar port-map custom-09 udp
ip nbar port-map custom-09 tcp
ip nbar port-map custom-08 udp
ip nbar port-map custom-08 tcp
ip nbar port-map custom-07 udp
ip nbar port-map custom-07 tcp
ip nbar port-map custom-06 udp
ip nbar port-map custom-06 tcp
ip nbar port-map custom-05 udp
ip nbar port-map custom-05 tcp
ip nbar port-map custom-04 udp
ip nbar port-map custom-04 tcp
ip nbar port-map custom-03 udp
ip nbar port-map custom-03 tcp
ip nbar port-map custom-02 udp
ip nbar port-map custom-02 tcp
ip nbar port-map custom-01 udp
ip nbar port-map custom-01 tcp
no ip sctp authenticate init
no ip sctp authenticate init-ack
no ip sctp authenticate shutdown-complete
no ip sctp authenticate authentication
ipv6 nd ns-interval 0
ipv6 nd dad time 0
kerberos timeout 15
multilink virtual-template 0
max-calls any 65535 direction in
max-calls any 65535 direction out
max-calls voice 65535 direction in
max-calls voice 65535 direction out
max-calls data 65535 direction in
max-calls data 65535 direction out
description
trunk group lpcor does not exist
max-retry 0
description
translation-profile outgoing PROFILE_ALL_T1E1
WARNING!: secondary export device is same as primary
%Text Relay needs to be enabled before the options being configuredPort number already in use.Port number already in use.
max-dn 0
max-pool 0
Aborted: invalid tftp path
define-abcd loop-open 0 0 0 0
define-abcd loop-closure 0 0 0 0
trunk-group ALL_T1E1 65
ip tcp mss 0
ip tftp min-timeout 3000
Requested number of permanent buffer elements is less than current value.
This configuration will get effected on the next reload.
buffers header min-free 0
buffers header initial 0
buffers fastswitching permanent 384
buffers fastswitching min-free 128
buffers fastswitching initial 0
%FastEthernet0/0 is a static pool and cannot be tuned
% is a static pool and cannot be tuned
%Dot11Radio0/5/0 is a static pool and cannot be tuned
37
