Cisco VRF Route leak
alanchia2000
I have 2 switches (Core sw, Access sw) which I have set up. VRF has been set up on the Core sw with Access switch connected to it. Now, I am trying to ping from the access switch to a network outside the VRF zone which the access switch is in. But it seems like it just won't work unless route leakage has been configured. I have done it, but it just wouldn't work for me. Following and attached contains my configuration. Would appreciate all the help. Thanks.
Description:
1. VRF "ClientA" set up on core switch
2. Gi1/0/2 (192.168.1.1/24) was configured as part of VRF "ClientA"
3. Loopback1 interface on core switch has been configured with an IP of 192.168.2.1/24 (Lo1)
4. An access switch has been configured - Gi1/0/14 (192.168.1.2/24).
5. Switch port of Gi1/0/2 is linked up to Gi1/0/14 via ethernet cable
Problem :
Unable to ping 192.168.2.1 on access switch
Question:
What is the proper method to perform route leakage from the VRF zone "ClientA" to Global routing table
Switch configuration:
Core sw
ip classless
ip vrf clientA
rd 100:110
route-target export 100:110
route-target import 100:110
interface GigabitEthernet1/0/2
description 192.168.1.2
no switchport
ip vrf forwarding clientA
ip address 192.168.1.2 255.255.255.0
end
interface Loopback1
description LoopBack interface for ClientA VRF
ip address 192.168.2.1 255.255.255.0
end
interface GigabitEthernet1/0/3
description 192.168.2.1
no switchport
no ip address
end
ip route 192.168.1.0 255.255.255.0 GigabitEthernet1/0/2
ip route vrf clientA 192.168.2.0 255.255.255.0 Loopback1
Access switch
ip classless
interface GigabitEthernet1/0/14
description TestVRF1
no switchport
end
Harold Ritter
Try adding a vrf static route on the access switch for 192.168.2.0/24 with a next hop of 192.168.1.2.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
your gateway should be a gateway within the vrf.
use the ip address under GigabitEthernet1/0/2 because GigabitEthernet1/0/2 is forwarding the the vrf. ip is 192.168.1.2
see this http://www.cisco.com/en/US/tech/tk436/tk832/technologies_configuration_example09186a0080231a3e.shtml
Thought the VRF static routes are only added to the core switch.
Anyway, what I tried on the access switch is :
ip route 192.168.2.0 255.255.255.0 192.168.1.2
Apparently, the above does not work. I tried to ping the loopback interface, but am still having issues.
