11-25-2011 06:23 AM - edited 03-07-2019 03:36 AM
Hello All,
Please i need clarification on a subject. I currently have 2 Cat6509 switches with VSS Capable Sups. One of the switches has an extra 10Gig Lincard. Will VSS still work in this scenerio?/?
R
Solved! Go to Solution.
11-25-2011 07:36 AM
Josh,
Yes, as long as you have the same exact sup and IOS in both devices, you can for example have 5 line cards in one and 4 in the other one or any other combinations. You don't have to have the same amount of cards in both devices.
11-25-2011 07:36 AM
Josh,
11-25-2011 07:40 AM
Thanks....This really helps!!
