cisco WS-C3512-XL with bad ports
Anyway to reset the ports with the IOS? How can I troubleshoot to make sure they are bad and not just something with the IOS.
this is what I get from a reload
00:00:09: %LINK-4-ERROR: is experiencing errorsFOUND an unknown transceiver on
port 5
FOUND an unknown transceiver on port 6
FOUND an unknown transceiver on port 7
FOUND an unknown transceiver on port 9
FOUND an unknown transceiver on port 10
FOUND an unknown transceiver on port 11
FOUND an unknown transceiver on port 12
port 1, 5, 6, 7, 8, 9, 10, 11, 12 are orange and the SYSTEM led on the front panel is also orange.
1 ACCEPTED SOLUTION
Re: cisco WS-C3512-XL with bad ports
Hi Friend,
It's a bad hardware now. Get it RMAed.
Ankur
Hi Friend,
Ankur
dang. oh well. it was a nice switch that I wanted to use. Fortuneately, it was a spare switch so we're not hurting the network.
thanks.
117
