Webcast-Catalyst9k
CISCO WS-C4948-10GE SFP+
Hello, I have a pair of CISCO WS-C4948-10GE's that we need to connect to a new switch that has SFP+ and QSFP ports. Is there an X2 module that supports this? If so, can someone name the part number that will work? I have found some information, but want to make sure I have the correct part number for our exact switches.
Everyone's tags (1)
1 REPLY
Bronze
Hello, Prosperent. You can
Hello, Prosperent. You can check this compatibility matrix to make sure that the 10G SFP module for your WS-C4948-10GE will be compatible:
Compatibility Matrix:
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6974.html
Please send me an e-mail at (adawa@cisco.com), in case you have additional concerns or need local Cisco support. Kind regards.
81
