Silver
cisco1861
hello
is the integrated switch in cisco1861 router L3 or only L2?
can we configure one port by the "no switchport" command ?
thanks
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: cisco1861
Oussama
I do not have experience with this module and so am not authoritative, but here is what I believe are answers to your questions.
You ask if this switch is L2 or L3. The switch gives you L3 capability by configuring VLANs and VLAN interfaces, and routing through the VLAN interfaces.
You then ask if you can make a switch port a directly routing port by configuring no switchport. This switch does not support that functionality. Its ports access VLANs and you do the L3 functions through VLAN interfaces.
Rick
Re: cisco1861
hi
as per the datasheet they are very much similar to the switchports available in fixed 1800 series model routers.
You have POE support enabled in these routers .
http://www.cisco.com/en/US/prod/collateral/routers/ps5853/ps8321/product_data_sheet0900aecd806c4dce.html
regds
Re: cisco1861
Oussama
Rick
136
