cisco1941K9, HOW TO SOLVE THE PASSWORD EXPIRATION?
jjpkayembe
I was not care when  I started to set the config on the new cisco 1941 K9, and I switched it off to do other thing urgent!
But when I came back to continu the config, I couldn't log in!!!
Please, I need help!  Here is the startup on my CISCO 1941 K9:
System Bootstrap, Version 15.0(1r)M12, RELEASE SOFTWARE (fc1)
Copyright (c) 2011 by cisco Systems, Inc.
Total memory size = 512 MB - On-board = 512 MB, DIMM0 = 0 MB
CISCO1941/K9 platform with 524288 Kbytes of main memory
Main memory is configured to 64/-1(On-board/DIMM0) bit mode with ECC disabled
Readonly ROMMON initialized
program load complete, entry point: 0x80803000, size: 0x1b340
IOS Image Load Test
___________________
Digitally Signed Release Software
program load complete, entry point: 0x81000000, size: 0x34df0c8
Self decompressing the image : #################################################        ################################################################################        ################################################################################        ################################################################################        ###################### [OK]
Smart Init is enabled
smart init is sizing iomem
                 TYPE      MEMORY_REQ
    Onboard devices &
         buffer pools      0x01EF6000
               TOTAL:      0x01EF6000
Rounded IOMEM up to: 32Mb.
Using 6 percent iomem. [32Mb/512Mb]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.1(4)M3, REL        EASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 06-Dec-11 16:02 by prod_rel_team
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO1941/K9 (revision 1.0) with 491520K/32768K bytes of memory.
Processor board ID FCZ160120WG
2 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
255744K bytes of ATA System CompactFlash 0 (Read/Write)
SETUP: new interface NVI0 placed in "shutdown" state
Press RETURN to get started!
Jan  2 12:00:02.375: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name        = c1900 Next reboot level = ipbasek9 and License = ipbasek9
May 29 06:06:54.603: %IFMGR-7-NO_IFINDEX_FILE: Unable to open nvram:/ifIndex-tab        le No such file or directory
May 29 06:07:04.719: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state        to down
May 29 06:07:04.719: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state        to down
May 29 06:07:05.815: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthe        rnet0/0, changed state to down
May 29 06:07:05.815: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthe        rnet0/1, changed state to down
May 29 06:07:08.263: %LINEPROTO-5-UPDOWN: Line protocol on Interface NVI0, chang        ed state to up
May 29 06:07:09.111: %LINK-5-CHANGED: Interface Embedded-Service-Engine0/0, chan        ged state to administratively down
May 29 06:07:10.147: %LINEPROTO-5-UPDOWN: Line protocol on Interface Embedded-Se        rvice-Engine0/0, changed state to down
May 29 06:07:13.975: %SYS-5-CONFIG_I: Configured from memory by console
May 29 06:07:15.967: %LINK-5-CHANGED: Interface GigabitEthernet0/1, changed stat        e to administratively down
May 29 06:07:16.055: %LINK-5-CHANGED: Interface NVI0, changed state to administr        atively down
May 29 06:07:16.623: %SYS-5-RESTART: System restarted --
May 29 06:07:16.707: %SSH-5-ENABLED: SSH 1.99 has been enabled
May 29 06:07:16.807: %SNMP-5-COLDSTART: SNMP agent on host GCM_LC is undergoing        a cold start
May 29 06:07:17.423: %LINEPROTO-5-UPDOWN: Line protocol on Interface NVI0, chang        ed state to down
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE  PUBLICLY-KNOWN
CREDENTIALS
Here are the Cisco IOS commands.
username <myuser>  privilege 15 secret 0 <mypassword>
no username cisco
Replace <myuser> and <mypassword> with the username and password you want
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL NOT BE ABLE
TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
User Access Verification
Username:
Thanks!
This link open fine for me - I just tried. I copied the steps below from the guide, though it is a bit large:
Step-by-Step Procedure
Perform these steps in order to recover your password:
  1. Attach a terminal or PC with terminal emulation to the console port of the router. Use these terminal settings:
    Refer to these documents for information on how to cable and connect a terminal to the console port or the AUX port:
    • 9600 baud rate
    • No parity
    • 8 data bits
    • 1 stop bit
    • No flow control
  2. If you can access the router, type show version at the prompt, and record the configuration register setting. See Example of Password Recovery Procedure in order to view the output of a show version command.
    Note: The configuration register is typically set to 0x2102 or  0x102. If you can no longer access the router (because of a lost login  or TACACS password), you can safely assume that your configuration  register is set to 0x2102.
  3. Use the power switch in order to turn off the router, and then turn the router back on.
    Note:
    • In order to simulate this step on a Cisco 6400, pull out and then  plug in the Node Route Processor (NRP) or Node Switch Processor (NSP)  card.
    • In order to simulate this step on a Cisco 6x00 with NI-2, pull out and then plug in the NI-2 card.
  4. Press Break on the terminal keyboard a couple of times after you see the message program load complete, entry point: 0x80008000, size: 0x6fdb4c in order to put the router into ROMMON.
    Note: The values of entry point and size are subjected to the routers.
    If the break sequence does not work, refer to Standard Break Key Sequence Combinations During Password Recovery for other key combinations.
    If unable to break into ROMMON mode, perform these steps:
    1. Remove flash.
    2. Reload the router. Router will end up in ROMMON mode.
    3. Insert flash.
    4. Perform standard procedure for password recovery.
  5. Type confreg 0x2142 at the rommon 1> prompt in order to boot from Flash.
    This step bypasses the startup configuration where the passwords are stored.
  6. Type reset at the rommon 2> prompt.
    The router reboots, but ignores the saved configuration.
  7. Type no after each setup question, or press Ctrl-C in order to skip the initial setup procedure.
  8. Type enable at the Router> prompt.
    You are in enable mode and should see the Router# prompt.
  9. Type configure memory or copy startup-config running-config in order to copy the nonvolatile RAM (NVRAM) into memory.
    warning Warning: Do not enter copy running-config startup-config or write. These commands erase your startup configuration.
  10. Type show running-config.
    The show running-config command shows the configuration of the router. In this configuration, the shutdown command appears under all interfaces, which indicates all interfaces  are currently shut down. In addition, the passwords (enable password,  enable secret, vty, console passwords) are in either an encrypted or  unencrypted format. You can reuse unencrypted passwords. You must change  encrypted passwords to a new password.
  11. Type configure terminal.
    The hostname(config)# prompt appears.
  12. Type enable secret in order to change the enable secret password. For example:
    hostname(config)#enable secret cisco
  13. Issue the no shutdown command on every interface that you use.
    If you issue a show ip interface brief command, every interface that you want to use should display up up.
  14. Type config-register . Where configuration_register_setting is either the value you recorded in step 2 or 0x2102 . For example:
    hostname(config)#config-register 0x2102
  15. Press Ctrl-z or end in order to leave the configuration mode.
    The hostname# prompt appears.
  16. Type write memory or copy running-config startup-config in order to commit the changes.
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards,
Ivan
5 Replies 5
Tagir Temirgaliyev
you need to reset your password
find in google full and detailed description of
Ivan Shirshin
Hi Jean,
You need to do a password recovery. Here is a procedure:
http://www.cisco.com/en/US/customer/products/ps5855/products_password_recovery09186a0080b3911d.shtml
Kind Regards,
Ivan
Kind Regards,
Ivan
PAGE ERROR WHEN I CLIC ON THE LINK,
THNKS
    • 9600 baud rate
    • No parity
    • 8 data bits
    • 1 stop bit
    • No flow control
    Note:
    1. Remove flash.
    3. Insert flash.
Kind Regards,
Ivan
Kind Regards,
Ivan
Mbaye Dieye
Many Thanks you saved my life.
Best Regards.
