cisco2811 router with vwic-1mft-g703
Helo
Recently implemented branch office with cisco2811 router with vwic-1mft-g703 configured for 1-31 timeslots. And the symptom is that the wan link connected tothe g.703 port goes off and back on automatically about the same time everyday.
Appreciate any lead on troubleshooting this issue and specifically on g.703 links
Re: cisco2811 router with vwic-1mft-g703
Check the controller status for errors
Narayan
In addition to Narayan's post,I would suggest to do the local and remote loop testing when this problem happens. Talk to your telco and try to get them involved in the loopback testing. If test the local loop i.e from telco's MUX to your router end.If that's fine then check the remote loop from the far-end mux and check if still the problem is there.If yes,could be a media problem from Telco's end.
HTH,
-amit singh
Hi All
Thanks. It was the telco fiber cable having the problem.
401
