02-02-2007 05:13 AM - edited 03-05-2019 02:07 PM
Hi Net Pros...I setting up a new 6513, and observe that the sup720 engine in slot 8 boots by default. But when I failover the sup engine in slot7 is take over and working fine.
'sh mod' and diagnostics doesn't detect any issue with both sup engines. Anybody had faced any similar issues? or any bugs with IOS 12.2(17d)SXB1 might causing this? Any help?
Thanks in advance.
02-02-2007 06:37 AM
How are you performing failover?
-HSRP?
-Blade removal etc ?
02-02-2007 10:35 AM
Hi, Thanks for the reply.
Testing the failover by blade removal, and the Sup engine in slot 7 is working fine.
But only during the booting with both the Sup., slot 8 is becoming active.
Don't know the reason why Sup at slot 7 not become active, which should be the default behaviour.
02-02-2007 11:55 AM
Both sups will be tested at POST and after POST the standby sup will -seem- to be inactive but if everthing is working correctly there will be no issue.
To support this, perform a sh mod after the switch is completely up.
One will be marked HOT and one Active.
also, show redundancy.
I hope I am understanding your question. Please post outputs if needed.
HTH, please rate for me
