clear arp table every 5 seconds
jjoseph01
Level 3
Level 3
Hi all.  I am in need to have the arp table cleared every 5 seconds or so on a 2800 router.  I was wondering how I might be able to accomplish this.  Anyone have any ideas on how to do this?
Vivek Ganapathi
Level 4
Level 4
Not sure, why would you want to do this. Nevertheless, there is no such command to do it on a router. But you can use schedule a batch job to execute automatically every 5 seconds. You can accomplish this with some TCL script or use of Ciscoworks, HPNA or Kiwi cat tools. I have never used Kiwi Cat tools though for this.
Vivek
Easiast way I guess to write EEM script. I guess it should look like this:
event manager applet CLEA_ARP
event timer watchdog time 5.0
 action 1.0 cli command "clear ip arp"
So you just configuring this in conf t mode. Though better to test that in a lab before applying to production.
More configs can be found here:
http://www.cisco.com/en/US/docs/ios/netmgmt/configuration/guide/nm_eem_policy_cli.html
Hope this helps,
Nik
HTH,
Niko
Oh yes, forgot this completely. EEM's are awesome
Thank you guys for your replies.  I dont know much about EEM, but Ill look into this and learn what I can.  Thanks again.
