clear cdp command
Hi, this is a really basic question but one I need to be sure of before running it on a switch, when the #clear cdp table command is run, the switch will automatically look for it's cdp neighbors again won't it? It's not traffic affecting, i.e, I won't loose connectivity to the switch when logged in remotely?
Thanks in advance for you help,
C
Re: clear cdp command
You are correct in your question and you will not lose connectivity (just verified it).
Thanks a million for your quick response. It's one of those things that I never thought of until I had to do it! Then I began to question it!
Thanks again
Carina
291
