Community Member
clear channel settings in CatOS
I did a "show config" and noticed
#frame distribution method
set port channel all distribution mac both
set spantree portfast 5/21-22 disable
set spantree bpdu-filter 5/21-22 disable
#port channel
set port channel 5/21-24 779
how do I clear these configurations under CatOS
1 ACCEPTED SOLUTION
Hall of Fame Super Bronze
Re: clear channel settings in CatOS
One of my pet-peeves with CatOS. Once you enable a feature and you disable it, the command remains there as 'disable'.
As for the port channel, the ports are actually bundle like in IOS, they are just sharing the same port ID. They are only bundle if you use set port channel command
HTH,
__
Edison.
1 REPLY
HTH,
__
Edison.
483
